all interior lighting is dead?
Old 01-22-2009, 08:06 PM
xRelapse13's Avatar
Default all interior lighting is dead?
When i turn my headlights on all my interior lights stay off. the HU display dims to nothing and none of my gauges or buttons light up. If i click the dimmer up all the way the dome and mirror lights will come on but everything stays dim. Any ideas. I'm assuming its the fuse but i can't pull it till i get home on sat. If it was the fuse, wouldn't just the gauges be dark though?
Old 01-22-2009, 09:05 PM
nemss1's Avatar
ya check the fuse. fuse controls gauge, radio, stock switches, steering wheel controls etc i believe
Old 01-22-2009, 09:10 PM
xRelapse13's Avatar
oh yeah, weird thing is that the steering wheel controls still light up? I'll check the fuse asap.
Old 01-22-2009, 09:35 PM
nemss1's Avatar
oh ya, forgot about that......steering wheel controls have a seperate fuse for their lights. 2 fuses for steering wheel controls: 1 for the function and 1 for the lights. my mistake
Old 01-22-2009, 10:56 PM
xRelapse13's Avatar
Alright, sounds like its the fuse. I'll check it either tomorow if i can manage to get it out, or when i get home on sat. thanks for the help man.
Any reason why it would just randomly blow?
Old 01-23-2009, 01:21 AM
nemss1's Avatar
no prob man. mine has randomely blown once on startup
Old 01-23-2009, 01:52 AM
SamhainZ28's Avatar
I had the same problem where all the lights went off in the cluster/radio. I checked the fuse but no dice. I figured out the problem was the orange wire that goes to the light switch was burned out. Changed it and never had the problem again. May not be your problem, just giving my .02
Old 01-23-2009, 01:22 PM
xRelapse13's Avatar
thanks alot man, if its not the fuse i'll def look into that.
Old 01-23-2009, 07:44 PM
xRelapse13's Avatar
checked the 10A gauge fuse today and it looked like it was fine. Any other fuses i can check?
Old 01-24-2009, 12:59 AM
blindxeyed's Avatar
Try replacing it anyway, just because it looks okay doesn't always mean it is. Just some advice from my own personal experience.
Old 01-24-2009, 08:52 AM
Flaring Afro's Avatar
i have an electrical problem too. my gauges dont light, and the stock radio LED goes out when i turn my headlights on. steering wheel controls still glow though and my interior lights work. if i replace the fuse it happens again in a few months and i just replace the fuse again. i dont see the point in spending $1k plus having someone look for the problem, or spending the time doing it myself.
Old 01-25-2009, 04:01 AM
xRelapse13's Avatar
Default 5A Dimmer Fuse Keeps Blowing!!
i found the problem was the dimmer fuse. But now it keeps blowing, I'm talking almost everytime i start the car the fuse blows. Any ideas whats going on. This is making driving at night a real pain in the ***.
Old 01-25-2009, 08:42 AM
^ mine was the dimer too. im no expert but i assume it the engine's grounding. that makes the most sense. if you can put the key in and turn to ignition without starting and it doesn't blow than it most be the engine itself sending a shock, you would think.
Old 01-25-2009, 12:25 PM
xRelapse13's Avatar
Checked under the dash, don't see any broken wires or uninsulated wires, the wires coming from the dimmer look like they work fine. Anybody got any ideas?
Old 01-26-2009, 02:02 PM
xRelapse13's Avatar
anybody?
Old 01-26-2009, 02:24 PM
PERFECT Z28's Avatar
Maybe the dimmer itself might be bad...
Old 01-26-2009, 03:41 PM
if his is like mine the dimmer itself works, on the steering wheel controls.
Old 01-26-2009, 04:01 PM
Could be a hamster living in the dash causing mayhem...
j/p
Old 01-26-2009, 07:49 PM
xRelapse13's Avatar
j/p
That would explain that rustling....
Brilliant....I'll take two
the dimmer works when i put in a new fuse up until it blows....lol
Old 01-27-2009, 07:50 PM
xRelapse13's Avatar
nebody?
