First spray TNT 150...
Well I sprayed my motor for the first time today...I'm instantly addicted. Need to save for new short block!
Sprayed a 150 on my heads/cam/TH350 car. (only jets I had at the time)
Stock fuel system.
FP guage was reading in the mid 50's through the sprays.
AF guage was reading on the mid-rich side.
I didn't spray through the shifts yet.
10 lb. bottle now empty, $27.00 poorer...
Hella faster. I was amazed at the difference, car pulled twice as hard and every bit as hard as my buddy's 10.2 second ride I rode in in between runs.
Any comments on the guage readings greatly appreciated, I dont have A-tap...
Stock fuel system.
LSX Mechanic
Re: First spray TNT 150...
If you're stock fuel system was still holding 50 PSI on a 150 shot of TNT with heads/cam, you're fuel pump must have been installed by GOD himself. I have never heard of a stock fuel system holding that much pressure with those mods. You might want to A-tap to make sure, thats sounds RISKY. Good luck
Josh
Josh
King, No Dyno, street runs only.
Damian, Ya, I'll be down jetting, but no access to A-tap. The Air/Fuel guage was reading RICH and fuel pressure was fine, but I still agree its too risky. Especially with the stock bottom end. My rod bolts wouldn't last too long...
Dam bro you might break out of the 14's for once, LOL
Now go to the track and put some times down and see how much fun the gas really is
JET
JET
