95 carbed ls6 camaro
ck out you-tube at http://www.youtube.com/watch?v=39qnxJH5CME and let me know what you think.
I live in St. Charles MO , Some of the parts list for the build are,Strange 12 bolt with 456 gears and a full spool,spohn lower control arms and panhard bar,sub frame connectors,rebuilt ls1 t56 trans with all the goodies(built to hold over 900 hp), spec 3plus clutch, adj master cylinder, spohn relocate adj torqe arm, sphon tub k-member, sphon sold motor mounts, rebuilt ls6 motor with stock crank but aftermarket rods and coated pistons,ls7 lifters,ls2 timming chane,the older bigger ms4 cam (651 lift),ls6 heads with a little head work with springs, topped off with a victor jr intake and a 850 carb. and a nos plate system with a msd box,with a set of 325/50/15 MT drag radials. All new from front to back. Motor should make 600 hp at the crank without the plate system. All out should be around 700hp to the wheels. It only has about 150 miles on all of it. If any body is looking for a good very fast car this is the one. I need to sell......
thanks for looking
thanks for looking
