Cam card question
Cam card question
ordered my 230 230 612 592 custom grind throguh vengeance from comp and the cam they sent me is a 230 230 613 591. Vengeance is closed and idk what to do or if the cam card is wrong or if itd even matter. Any suggestions?
Also just looked the lobe numbers up on the cam card they match the ones they were suppose to be but neither say xfi or xer
Its says 3016R /3725R but it was suppose to have xfi and xer lobes
so as of now you got sent the right cam...now you just have to degree it when you put it in to make sure it was cut right...I am sure you will be fine...
also when you degree it, it is acceptable to be within a +/- 1 degree...so it could be a 229 or 231...
you are fine that is the right cam...my intake and exhaust lift are the same...it is really hard to cut a cam 100% to the thousandth...
