My lt1 bucks or bogs
i have a 95 camaro z28 with a lt1. When i got the car it had the rubber elbow on it . it was cracked i replaced it with the trick flow elbow aluminum kit. it stop the bucking for about a day or two but now is back .no where near as bad but is still notice able any suggestions. please help
To see if it is the MAF itself that is the problem, disconnect the MAF wiring harness and drive the car for a bit. Yes the car will drive without it because the ECU (Engine Control Unit) will go into a mode that doesn't use the MAF's input when it senses the MAF isn't sending any. If the problem changes for the better, either clean or replace the MAF. If it doesn't, you have another problem. Don't run the MAF-less car too long but a half hour won't hurt and is long enough for your diagnosis.
