Transmission Yoke O-ring
Old 01-25-2009, 09:07 PM
camerory's Avatar
Default Transmission Yoke O-ring
I bought an aluminum driveshaft off someone on here to swap out my stock one. I am rebuilding the aluminum shaft with new u-joints so I know they are good. There is a black o-ring on the inside of the yoke (transmission side) that is cracking. Should I replace this o-ring, if so does anyone know its name or part #?
Thanks
Old 01-26-2009, 11:07 AM
Stroked96Bowtie's Avatar
Sounds like a transmission taleshaft o-ring...just call a local parts house they are commonly replaced. If its bad it should be leaking...if its not leaking Id live it alone.
Old 01-26-2009, 03:09 PM
camerory's Avatar
Yeah, it isn't leaking because it is part of the driveshaft. It is pressed into the steel yoke on the driveshaft. I am thinking they might have put it there so the yoke doesn't bump into the tailshaft housing.
Quick Reply: Transmission Yoke O-ring
