What plug and gap should I run for 250 shot?
Old 10-06-2003, 05:18 PM
Back in the staging lane
Beeler422's Avatar
Default What plug and gap should I run for 250 shot?
Going to spray the 422 with about a 250 shot. What type of plug should I run and what should I gap it at? Thanks.
Old 10-06-2003, 05:38 PM
EVIL's Avatar
Default Re: What plug and gap should I run for 250 shot?
you gonna start off with the 250??
good lord!
dont let my little 346 get in the 9's before you do!
Old 10-06-2003, 05:56 PM
The Bull
DERTY's Avatar
Autolite AR472 with a .035 gap can get you started. That's the coldest damn plug you can get so you might want to start there and work up, but I doubt you will need to. That's what I use in mine, ARE uses it in the Silver Z, Taner, RomanSS, Tom Kempf and a few others use it as well.
Old 10-06-2003, 08:31 PM
Moderator
BADZ's Avatar
Are they suppose to be fast guy's and fast cars????
Old 10-07-2003, 07:25 AM
The Bull
DERTY's Avatar
Small disclaimer, the AR472 is only a plug you can use on race day and to put the car on and off the trailer. You cannot motor pass or drive on the street with them, they are too cold.
Old 10-07-2003, 09:41 AM
Beeler422's Avatar
so what plug can I use to also make motor passes with?
Old 10-07-2003, 12:03 PM
The Bull
DERTY's Avatar
You can switch over to NGK's and run those too. TR6 Should be fine on motor. Maybe a TR7 if it's an all out race motor. I just use TR6's and it runs well on motor but I would never spray on them.
Old 10-07-2003, 11:04 PM
Ron@Vengeance's Avatar
Im hosing a 200 shot on TR6s with 12:1 with NO issues........... Tuning is the key factor here...
Old 10-09-2003, 04:58 AM
badass 2002 z28's Avatar
Not trying to hi-jack this thread, but what makes you say AR472's are a racecar only plug? Why can't you drive on em? You can PM me if you want
Old 10-09-2003, 02:39 PM
The Bull
DERTY's Avatar
Simple, they are 8 to 9 ranges cold. You'll foul them up because the motor doesn't do enough to use that cold of a plug on it's own. It runs like chit basically. Going back to a TR6 makes the motor a bit happier.
Old 10-09-2003, 02:56 PM
andy98Z's Avatar
DERTY....NGKs are 1 step colder, Autolites' are 8-9?
Is there a plug in between about 4 steps colder than stock?
That doesnt sound like fun, having to change plugs when I want to spray.
Old 10-09-2003, 03:32 PM
The Bull
DERTY's Avatar
A TR6 is one range colder, a TR7 is two, a TR8 is three. All three can be purchased from an NGK dealer or from Thunder Racing I believe. Autolites offer the same spectrum continuing down from there in their racing plugs. They end at like 5 ranges colder (AR472) or something like that. You can also get an equivalent NGK racing plug to the AutoLite. You'll have to go through the respective books for the part numbers because I don't have them around.
Edit: Autolites end 5 ranges colder not 8. Too confused with the numbers of the different plugs.
Old 10-09-2003, 03:33 PM
andy98Z's Avatar
Then would you be able to run on motor, cruise around on the street and spray it hard?
Old 10-09-2003, 04:00 PM
The Bull
DERTY's Avatar
No, if the plug is too cold the motor will foul the plugs. You need to raise the heat range until it quits fouling. You typically run a colder plug when you are spraying bigger shots. Some can get away with motoring around on a TR6 or 7 and spraying on top of it. Everyone's setup is different and you have to find your own safe setup from there.
Old 10-09-2003, 04:27 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
RickC6 and Slowmaro use the TR8's.
Old 10-10-2003, 03:38 PM
TEA Brent's Avatar
we ran NGK V-power R5724-8's on Brians C5 when it ran 9.87@139 which is a 100 dry/150wet setup. This plug is better than a normal TR plug because the tip has a groove cut in it and the electrode is cut back to open up that tip more.
We've driven the car back and forth to the track 3 times ( 60-70 miles est) with these plugs in... no misfire or ignition problems yet.
Old 10-10-2003, 03:40 PM
TEA Brent's Avatar
oh gapped at .035
Quick Reply: What plug and gap should I run for 250 shot?
