ms4 cam, stock heads, can i raise the cp by using a thinner hd gasket. without flycut
Old 01-26-2009, 02:51 PM
matthewjosh's Avatar
Default ms4 cam, stock heads, can i raise the cp by using a thinner hd gasket. without flycut
Let me know what you think guys.. What is the thinest gasket I can put in to get the compression up a bit? Remember stock heads ms4 cam....
Old 01-26-2009, 04:28 PM
chrs1313's Avatar
no, do a search, the PTVC is very close even with stock gaskets...just give Texas Speed a call, they will give you all of your answers right away...
Old 01-26-2009, 05:59 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
I would not run a thinner gasket on a set up like that. We typically run the GM MLS gaskets on our MS4 cam only installs.
Old 01-27-2009, 08:09 AM
Ok thanks, I am going to put some heads on some time soon I will just wait
Old 01-27-2009, 11:40 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
The PRC 215 heads will give you smaller chambers & clearance for the MS4 camshaft. We recently had a customer make over 485rwhp with a smaller Tsunami camshaft & the PRC 215 heads. We can get you 59cc chambers & clear the MS4!!
http://www.texas-speed.com/shop/item...d=993&catid=40
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
