Sick and tired of problems, hate life.
MY TRANSMISSION(700R4) AND/OR CONVERTER IS PROBABLY THE CULPRIT...
I DRIVE DOWN THE STREET FOR ACOUPLE MINUTES AND BAM! IT STALLS OUT AND LOADS DOWN THE ENGINE UNTIL IT SQUEEZES THE LIFE OUT OF MY ENGINE. I JUST DROPPED THE PAN LAST WEEKEND TO TRY AND FIGURE OUT THIS PROBLEM, THOUGHT IT WAS MY LOCKUP SOLENOID-PARTIALLY ENGAGING. SO I CLEANED EVERYTHING UP AND CHECKED THE SOLENOID, ITS FINE... CLEANED THE PORT OUT WERE IT PLUGS ALSO. THERE IS NOTHING IN THE PAN THAT RESEMBLES ANY KIND OF METAL FRAGMENTS. I DID A STALL TEST TOO, MY CONVERTER IS RATED AT 2800-3200 STALL... MY TEST SHOWED 2900ISH 3000ISH.... SO IT IS GOOD. I HAVE NO LEAKS, TRANS FLUID IS CLEAN AND AT THE PROPER LEVEL. THE TRANSMISSION(700R4) WAS FULLY BUILT WITH A STAGE2 TRANS GO AND SOME OTHER BEEFED UP PARTS. ALSO THE ENGINE IS A 5.3L V8-LS6 CAM-LS2 INTAKE-LONGTUBES... TUNED MY PCMFORLESS(TUNED FOR A MANUAL TRANS.. SO I COULD HAVE A NON ECM CONTROLLED TRANNY) I WIRED MY LOCKUP THROUGH VIA A WIRING DIAGRAM ON THIS SITE.. AND IT ALSO WORKS RIGHT.
BASICALLY, IM LOST... AND I AM TIRED OF NOT BEING ABLE TO ENJOY THIS PROJECT THAT I HAVE BEEN BUILDING FOR A YEAR NOW. I DONT WANT TO HAVE TO CUT MY LOSSES, IM A DIEHARD CAMARO AND CHEVROLET GUY..
I CANT EVEN DRIVE IT TO A REPAIR SHOP.. AND EVEN THEN, IM LOOKING AT A VERY EXPENSIVE REPAIR-MOST LIKELY.
IF ANYONE HAS ANY IDEA OR INFO, I REALLY DO APPRECIATE IT IN ADVANCE.
LATER.
LATER.
Yes, i had it this way before i did the pan drop this past weekend. Wiring it back up the right way i thought would help. I have a 4th gear clutch and 4-3 downshift press switch being used in my wiring. Do i need some kind of vacuum line somewhere on this tranny? Ive only got the tv cable.
Closed ex-Sponsor Account
Also check for any stuck valve and verify the enable soleniod is exhausting oil by blowing air through it. I have seen individual insert check ball in those soleniods to get the lock up and even a failed soleniod is possible.
with no electrical source, it only leaves me with a tcc valve with a calapsed spring..possibly or tranny could be running hot, causing the lockup to engage partially. i will have to air test. i just never done it before.. wish i had pictures.
