take a look at this 6.0 please
I could get a good deal on this 2007 2500HD with 97000 miles.
Are the newer 6.0 motors the same as the 2000 on up?? I know 99 and
2000 had a crank difference. I would like to put a 6/speed behind this.
So, is there any difference I should know about?? THANKS
76 camaro conversion with a 6/speed, so that should be alright, right??
I was gonna send the harness off to speartech to delete what was not needed.
Ill go back tomorrow and pull the cover.
i personally, if you can get it for a good price, i would just take the pan off, and change the rod and main bearings. around 180 bucks for both sets, and while your down there, put an LS2 timing chain and change the oil pump. just to be on the safe side. its all cheap insurance. if it does have trashed bearings, you run the risk of spinning one and trashing more parts.
Z06 cam in it, and a F-body oil pan, put it in the car and get it running
and driving. I know I would need f-body front pulley accessory also. Then
find a 98 to 2002 T-56 to mate up to it.
like most place's want to hit you up for
$1500.00 no trans. Don't need it anyway.
that motor has the 24X crank and 317 heads on it. You can tell from the three bolt throttlebody. the newer ones have a 90mm 4-bolt TB. I would get it, and when you swap pans just pull a cap off a rod and look and see if theres any wear, shouldnt be but just take a look and see. If there is then rod bearings if caught soon enough arent expensive.
