Cam un-tuned
Old 01-26-2009, 07:12 PM
clwz28's Avatar
Default Cam un-tuned
I will probably go with the cc502 or the hot cam,will they run ok till I get my tune?
Old 01-26-2009, 07:15 PM
C5042081's Avatar
it should run ok but a tune will get the most out of it
Old 01-26-2009, 07:19 PM
Elliott's94Z's Avatar
It will run but obviously not to it's full potential. Me personally, I wouldn't drive it a lot until the tune. With just a cam only you should be ok sending your PCM off for a mail order tune. You should just send it off before/during the swap that way by the time your finished it will be done and ready to put back in.
Old 01-26-2009, 08:06 PM
ss.slp.ls1's Avatar
I assume you meant CC503. That's the cam I have. I have a mail order tune from MadZ28. It runs perfectly. If you have to wait a while until you get a tune, it will run, just don't beat on it and you should be fine.
Old 01-27-2009, 09:59 AM
myltwon's Avatar
comp has multiple grinds: cc502, cc305, cc503, cc306, etc
I'd recommend a real dyno tune, car will be driveable with that cam without a tune but to get the most out you'll want one
Old 01-27-2009, 10:11 AM
ss.slp.ls1's Avatar
Oh, I knew of the CC306, and CC305, didn't know there was a CC502.
Old 01-27-2009, 11:20 AM
lt1noob's Avatar
what are your other mods and what do you have for #'s? ive been looking at this cam and am wondering what you make to the wheels.
Old 01-27-2009, 11:29 AM
ss.slp.ls1's Avatar
CC503
crane duals, CC 1.6 promags, guideplates, pushrods, ARP studs
SLP SS CAI
52mm TB
Pacesetter 1 3/4" LT headers and y-pipe, SLP 2OTL exhaust
stock heads & intake.
T56, 10-bolt
No dyno numbers yet, but I raced my buddy with a LS1 that dyno'd 340/350 from a roll at 55mph and he gets me by about 2 cars at 140 mph. Don't know if that tells you much though. This set up is "supposed" to put down around 330 rwhp.
Old 01-27-2009, 03:07 PM
1badzee's Avatar
My hotcam setup put around 340 0_o then again idk the specs on a 503
Old 01-27-2009, 05:21 PM
ss.slp.ls1's Avatar
224/230 .502/.510 (1.5 rr's) 112lsa. Definitely better than the hotcam.
Old 01-27-2009, 06:43 PM
LT1_T/A's Avatar
it will be driveable, but like these guys said i wouldnt beat on it until you get the tune..
Old 01-27-2009, 08:33 PM
1badzee's Avatar
So why did I make more power with a hotcam?
Old 01-27-2009, 09:10 PM
ss.slp.ls1's Avatar
Maybe your opti wasn't acting up that day...jk
Idk man, same mods? same tuner?
Old 01-28-2009, 07:34 AM
Wicked94Z's Avatar
CC502 will drive fine without a tune. I drove around with my CC306 untuned for 2 weeks no problems for the car it just ran kinda... rough. I wouldn't worry about babying the car either, you won't hurt it
Old 01-28-2009, 09:45 AM
bobdec's Avatar
Back to OP.. IMO without a tune the A4 it will idle like crap.. '94 stock idle setting is 550 RPM in drive , 650 in p/n .. with 305 or hot cam your up in the range of 218-224/ 228-230 , .500-.525 with stock rockers. However the 112 LSA is going to give you a rotten idle in drive at 550 RPM. Unless you want to throw it in 'N' whenever you stop, I would recommend one or all of --- add timing to the closed TPS table, tweak the TBS stop and add a couple hundred RPM's to the idle speeds keep it smooth at stop lites. Also you may want to move up the stall installation time table, that would help with idle and take advantage of the CAM.
Old 01-28-2009, 10:48 AM
myltwon's Avatar
my cc503 car made 325rwhp through midlengths and an unlocked stalled auto. this was on a 130k+ mile motor
Old 01-28-2009, 02:36 PM
clwz28's Avatar
Thanks for all the advice,I will be putting my stall in real soon,and next month or two do the cam(502cc),I read a thread on this cam laying down 328 rwh/358t on a bolt on 95 vette.
Old 01-28-2009, 06:27 PM
Wicked94Z's Avatar
does i don't think his idle quality will be too bad, especially if he has a 114 lsa not the 112
Old 01-28-2009, 09:45 PM
myltwon's Avatar
the idle quality between a 112 and 114 is pretty minimal
put a cc305 (114lsa) next to a hotcam (112lsa) and they'll sound like the same cam imo
big duration will also have an effect on lope
Quick Reply: Cam un-tuned
