Inspection pretty soon
Old 01-26-2009, 07:38 PM
tonys02slpss's Avatar
Question Inspection pretty soon
I have a 2002 Camaro SS SLP#5878 and it has LT headers with no cats.I have sims but the driver side went bad and I also had the air pump removed and my SES light is on.It says its my one bad sim and my air pump,but I already know that was why my SES light was on.My problem is I need to get it inspected and I heard that in North Carolina I can only have one thing that is bad and still pass is that true.Because if it is I just need to order that sim and then just my air pump will be setting the ses light right?
Old 01-26-2009, 07:59 PM
D_Rock's Avatar
You need to go to a tuner and get it all deleted off your computer. I went to R.P.M. in Garner, NC and passed inspection 2 weeks later. I just moved to Las Vegas from North Carolina and I passed Nevada SMOG. We shall see if I can pass next year when my QTP Race style's, ORY are installed and I am also going to delete my air. Im going to have fun trying to find someone to pass me.
Old 01-26-2009, 08:08 PM
Well see I have the race style headers too thats why the air pump had to be removed.They dont have no air connection or nothing.Will it still pass if I was to get the air pump and the sims erased off the computer?
Old 01-27-2009, 07:26 AM
ramairJP's Avatar
As long as you don't have an SES light and you go to the right place it will pass. Some places will actually do a visual, but I found a spot that only hooks it up to the computer and makes sure the headlights work in Raleigh, so with the tuning you'll be good to go.
Old 01-27-2009, 07:00 PM
See I would go but I'm pretty sure I have to drop the car off and leave it there,this is the only car I have to get to work.Is there a fuse just for the SES light?Maybe I could just take it off and go see if it passes?
Old 01-27-2009, 08:34 PM
99345hp's Avatar
they will probably do a bulb check and see if the light comes on when you turn the key on.
Old 01-27-2009, 11:03 PM
01ssreda4's Avatar
why would you have to drop the car off and leave it??
Old 01-28-2009, 04:19 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
if you have the light blocked visually or the bulb gouged out it will still fail. That light is just a friendly reminder that something is awry already. They will find it when the plug in and scan.
Old 01-28-2009, 07:47 AM
twitchtwice's Avatar
you have to get it deleted by a tuner in order for it to go away, if you dont it will come up when they scan it even though the light doesnt come on. just get a mail order tune or something where they can delete all those.
Old 01-28-2009, 03:39 PM
I guess I will just take it to a shop and get the codes deleted.What about if one day I want to put the cats back on will them codes ever be needed back?
Old 01-28-2009, 04:30 PM
no, they will be deleted and that it, their little scanner doesnt know any better. all it knows is when its throwing codes
