2.05 valve fit with .595 lift?
Re: 2.05 valve fit with .595 lift?
I doubt it will clear, I'm running same size intake, slightly more lift and 2 degrees more timing but I'd say you will be very close there.
Is this with or without the 1.8 rockers
My Heads are milled 0.010".
The XE-R 234 lobe has .598". Not sure how this will add up when we are talking about clearence compared to a .595". I'll have YT 1.7 rockers on a 110 ICL, 112 LSA, unmilled heads, and stock head gaskets. V8ute, you must a had to do some serious clearencing to get a 234/238 XE-R with 1.8 rockers to fit. That equals out to .630/.640 lift. Any one else have a suggestion?
Beast96Z, your right about the lift on my cam.
there's some major clearancing alright, they were measured/checked in the block and then unassembled and sent off to get machined.
