need advice
need advice
I am in the middle of a bad situation. I had planned on a head/cam LS1 with TSP 5.3 stage 2.5 heads and a custom grind 230/232 .613/.595 111+1LSA. Long story short, I have everything for the heads/cam but have an LS1 with bad cam bearings and I am sure main,rod bearings are right behind.
I then pick up an LQ4 with 17,000 miles on it. Pull the 317 heads and find a piece of piston ring broke and got loose in 2 of the cylinders, pitted the tops of 2 pistons and the bottom of the head, Along with a slight 1/2 long score in a cylinder wall.
I am thinking of boring, making a 370ci out of the 6.0 using my custom cam. My question is about the head choice and what pistons I need now. I would like to use Weisco pistons that can be used now and in a 408 with forged stroker crank, rods later. Which pistons do I need to use with the heads/cam?
I have been told to get L92's.
Would the 5.3 heads be too restrictive and not be using the full potential?
What are my best options right now?
