Beefing up the 10 bolt
Old 01-26-2009, 11:16 PM
tspence45's Avatar
Default Beefing up the 10 bolt
I know it's frowned upon, but I'm thinking of beefing up the 10 bolt a little. I figure, a beefed up 10 bolt should be able to handle the power levels that I'm expecting from my car in the near future. I'll be putting a cam in my car this spring, sometime. So, I'll just be looking at ~350rwhp. I don't think there's any need to upgrade to a 12 bolt or 9" at that power level. So, I've been looking at all the ways to beef up the stock rear. I've already got a MAC rear girdle laying around that will be put on when I do a gear install. I think I'm going with either Motive 3.73's, or 4.10's, with their Master install kit, since I found a site with the gears, and kit for $235. Then, I'm going to go with some Moser axles. I just want to clarify which axles I need. Since I don't have TCS, I have a 3-channel carrier, correct? So, I'd need these axles? http://store.summitracing.com/partde...134+4294839047
I'm just wanting to make sure that I've got all the part numbers correct before I start ordering stuff.
Old 01-26-2009, 11:37 PM
9000th01ss's Avatar
Thats the part number you need.
Old 01-27-2009, 12:54 AM
tspence45's Avatar
Alright, thanks. My buddy also said something about getting C-clip eliminators. Would they really be all that beneficial? And also, from the looks of it on Jegs, it sounds like I won't be able to have ABS if I run the C-clip eliminators.
Old 01-27-2009, 10:26 AM
9000th01ss's Avatar
C clip eliminators have no effect on ABS.
They keep the axle and tire on the car if an axle does break.
This can prevent a lot of body damage. Or not, the smallest OD of the axle is inside by the differential.
I think c-clip eliminators on stock axles would be fine.
Or good name aftermarket axles with c clips.
Old 01-28-2009, 04:30 PM
tspence45's Avatar
Well, I'm probably going to get the Moser axles, and c clip eliminators for them. Or would it not be necessary, because it'd be very unlikely to break the Moser axles at my power level?
Old 01-28-2009, 07:14 PM
9000th01ss's Avatar
Whatever you want to do.
You're not likely going to break an axle, even a stock one.
If you like spending money and want to be extra extra cautious, get the moser axles and c clip eliminators.
It'll only be more wasted when you start breaking ring and pinions.
With the mods in your sig? It's going to be a long time before you break a stock axle.
Old 01-28-2009, 07:40 PM
chaser2racing's Avatar
If your going to hook u need c clip eliminators or your axle and tire may come off and leave your quarter wrinkled up on the pavement
Old 01-28-2009, 09:14 PM
Elliott's94Z's Avatar
Slap a T/A Cover on and call it good. I wouldn't waste too much money on your 10 bolt. If it goes it goes man and if it don't then keep adding power until it does Being you have a M6 you are more **** to snapping it so save up for a 9 inch..
Old 01-28-2009, 10:38 PM
madclown's Avatar
I broke an axle right into a thousand pieces. I wouldn't put to much money into the stock 10 Bolt either. You are better off saving for a better setup. I have broken mine once and my friend has rebuilt his at least 4 times. They just are not able to handle the stresses. Also we are at over a mile high elevation and rearly see DA's under 7000ft. Point is I broke the stock axle without N2O so it was only about 300 actual RWHP. The corrected is 383RWHP. Save your money.......
Old 01-30-2009, 10:35 PM
01ssreda4's Avatar
who has the link to the big article on beefing up the ten bolt with the rod end kits welded to the TA cover???
Old 01-30-2009, 10:43 PM
Raptor_WS6's Avatar
do you have the link of the gears and kit at that price?
Old 01-30-2009, 11:08 PM
bluehawk2's Avatar
i wish I hadn't put a dime into trying to make my ten bolt stronger............waste of money
Old 01-31-2009, 11:31 AM
koolaid_kid's Avatar
http://www.geocities.com/duragizer444/install.html
Not saying I recommend it, BTW. Going for a 9 inch myself.
Old 01-31-2009, 01:02 PM
9000th01ss's Avatar
LOL god, this is funny. Search that guys name with "threads started by this user"
https://ls1tech.com/forums/gears-axl...osi-noise.html
Originally Posted by hazard2k
Argue all you want at what to buy for a rear end, but until someone gives me 2 grand so I can get a 9” to agree with them, I am going to do it this way.
I just finished up installing my new 9"
Something happened around 10/07 and 5/08
Weird how theres no explaination what happened to the stengthened up 10 bolt with those retarded preload bars on it, it started making noise, then he's installing a 9 inch.
Old 01-31-2009, 01:04 PM
9000th01ss's Avatar
A FABBED nine inch none the less.
Those aren't cheap.
Old 01-31-2009, 01:49 PM
billyb's Avatar
Default like this
http://www.lpwracing.com/p_axletubebrace.asp i got the cover only so-far.axel tube brace,might not work but it looks good !!!!!!!!!!
Old 01-31-2009, 04:21 PM
9000th01ss's Avatar
I'll pay someone to put bushings inside the rod ends of those preload bars, bushings that reduce the size of the bolt down to 1/4"
I bet the 1/4" bolts won't break.
If those preload bars do anything, they bend the housing, they don't prevent it. I could see if the housing to body mount was 18" from the end they might help. But on an f -body the forward forces are at the LCA mounts, which are a few inches from the end.
Old 02-02-2009, 07:37 AM
nitr0racing21's Avatar
I am telling you right now I had 305 wheel horse yesturday at the track and blew the ******* rear the dam 10 bolt is ****!
Old 02-03-2009, 12:03 AM
tspence45's Avatar
PM sent, since it's not a sponser, I don't believe.
Old 02-03-2009, 02:00 AM
HWI
HWI's Avatar
Other than swapping some 3.73s in, I'm not touching the 10-bolt. Once it blows up then I have a good reason to get a 12-bolt and of course while that's happening I may as well get a built tranny, then I need to get a 383 stroker built to give the tranny and rear end enough power.
