Torn elbow! what are the effects?
Old 01-27-2009, 02:02 AM
t/afrom504's Avatar
Default Torn elbow! what are the effects?
When I was taking off my air intake, i noticed the intake elbow was torn mostly at the bottom exactly where it connects over the throttle body. How can that effect the way my car acts?
Old 01-27-2009, 02:21 AM
Moderator
BizZzatch350's Avatar
When my car had a torn intake elbow it would randomly stutter and stumble on the highway. A GM 1LE is a good fix and only 40$ from Jason Cromer, if I still had it, I had a good GM 1LE you could have had seeing as your in Houston.
Old 01-27-2009, 02:25 AM
the_merv's Avatar
If it's pulling some air it will run rich and run crappy depending on how much it pulls in. Basically if the gap is behind the MAF, it will run like crap because the air isn't metered.
Old 01-27-2009, 02:44 AM
t/afrom504's Avatar
who is jason cromer? and does he sell them?
Old 01-27-2009, 09:20 AM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Jason works for, or used to work for, Sam Taylor Buick/Cadillac in Fort Walton Beach Florida. They have very, very good prices on parts and won't screw you on shipping. I've bought a lot of stuff from him.
You can find his contact info at www.shbox.com.
Old 01-27-2009, 09:38 AM
moderate Z28's Avatar
Mines torn in the same spot. I havent noticed any changes in the way it runs but its also a 93 model. No MAF sensor. I will be getting an aluminum elbow soon.
Old 01-27-2009, 10:01 AM
myltwon's Avatar
unmetered air getting into the motor post MAF (94-97) will throw off the a/f ratio
Old 01-27-2009, 10:24 AM
SchaefZ28's Avatar
Mines been torn since I bought the car about 3 years ago and it's always ran and drove great, probably because it's not a very big tear.. it's patched with duct tape
It hasn't caused me any problems so I'm not too concerned with it for now, someday I'll be getting either a 1LE or an aluminum one though.
Old 01-27-2009, 12:32 PM
1995blacktattop's Avatar
you'll fail emissions due to the car putting too much fuel in to compensate for the extra air. (or something like that, i know i failed emissions due to it) the car will also sometimes not want to start after its sat for awhile.
i know this from experience. it happened to me in the summer of 07.
it cost me $100 at a shop to figure this out :duh: and then i spent $90 at summitt for a new metal elbow. had i known i was gonna end up getting an oem ram air hood and an oem airbox w/ k&n for $425 (separately, the hood was $307 and the airbox was $115) i'd have left it with the duct tape on it for the 6 months it was on the road before i put it away last winter. you could only see 1 inch of duct tape if that on the side because it was all underneath. i ended up reselling the whole stock airbox assembly with the black powdercoated elbow for around $65
the first pic is with the powdercoated elbow i got from summitt and the second is how the engine looks now (the intake was painted during an intake manifold gasket change) and the first pic is kind of crappy because it was taken on a cell phone
Old 01-27-2009, 01:24 PM
Toronto_LT1's Avatar
like the guys said,unmetered air will throw off A/F ratio.i had the same thing happen to my stock unit so i switched to TF elbow i bought from Jegs.
Old 01-27-2009, 01:37 PM
DroppedM6Z's Avatar
I had a set up Toronto, Not only does it look better it is easier to replace the rubber if it tears later.
Old 01-27-2009, 09:50 PM
t/afrom504's Avatar
im going to see if i can order one from jegs, I really like how the alum. one looks too
Old 01-28-2009, 10:50 AM
myltwon's Avatar
trickflow makes the best one IMO
the vortec one looks bland and has that dumb air divider in it
Quick Reply: Torn elbow! what are the effects?
