vid: 242/250 112lsa in a 350
Old 01-27-2009, 10:55 PM
zigroid's Avatar
Default vid: 242/250 112lsa in a 350
http://www.youtube.com/watch?v=s7puQmREcBw
quick video I threw together of my car. I dont have many miles on it so I wasnt going to go beating on it. yes the burnout was weak haha once its broken in more Ill have some better videos.
I was surprised at the driveability of the big cam. I had a similar cam in my 383 (242/248 108lsa) but on much lazier lobes and I think this 242/250 112lsa cam drives better with stock cubes. converter locks up at 1700 rpm in 3rd, 1500 rpm in 4th, no bucking and surging. doesnt seem to have a whole lot of power down there, thats one place where my old 383 has it beat, but I don't need low end with a 4000 stall
specs:
350 cube bottom end using stock pistons and a crank and rods a friend gave me (unsure of origin, all I knew is they would work)
bottom end was assembled with ARP rod bolts, clevite bearings, hastings rings file fitted, and balanced to zero.
cam is a custom spec by ed curtis, 242/250 112 lsa, just under .600" lift.
comp 1.6:1 NSA pro mag rockers, Trickflow guideplates, comp 7.2" pushrods, stock LS2 lifters, PAC1518 valvesprings installed at a hair under 1.800" and about 130 lbs closed, chromoly retainers.
heads have some bowl work done, some port smoothing, and a good valve job. nothing major. chambers are in the mid 53.x range. compression comes in at about 10.9:1 with the mr gasket .026" thick head gaskets.
Stock LT1 intake opened up to 58mm and a little bit of porting done by myself (first time, hope it flows well lol)
BBK 58mm throttle body.
STOCK airbox. gonna do an LS1 lid conversion when funds permit. pointless to spend money on anything else.
Locally built 4L60E with a Yank Prothruster 4000 stall.
2.73... yes... 2.73 gears in a stock 10 bolt. 4.10s are next on the list, PCM is already programmed for them.
Pacesetter LTs and a pacesetter y-pipe hacked up with 2 electric cutouts in place. car is open y-pipe in the video, can't find the intermediate pipe to hook up to the hooker catback.
removed all the emissions crap, ABS delete, A/C delete, meziere electric waterpump, UMI tubular k-member.
PCM tuning by Ion at MadZ28 (he seems to have done a real nice job with this)
goal: I would like to run 11.99 or better all motor with some good tires and maybe some suspension work but ultimately I just want it to last so I can enjoy it and have fun with it... not have it sit for 2 years again with no engine.
Old 01-27-2009, 11:18 PM
StealthFormula's Avatar
Sounds awesome, cant believe how long you went without a motor I think that was way back when I had my other car when you tore it apart. How do you like the stall so far? Im thinking about switching to a PT3800.
Old 01-27-2009, 11:28 PM
zigroid's Avatar
the stall is pretty loose with the 2.73s, it really really really needs more gear. it seems to hit VERY hard, not sure about top end havent done that yet.
Old 01-27-2009, 11:30 PM
fergymoto's Avatar
Out of curiosity, why are you running such a large cam?
Old 01-27-2009, 11:32 PM
Moderator
BizZzatch350's Avatar
Sounds good, really glad to see you put it back together. Nice swirlie wheels
Old 01-27-2009, 11:38 PM
zigroid's Avatar
I told ed curtis what I wanted and what I had. freedom to rev to stock PCM limits, max power from 4000-7000 rpm, lots of gear, some weight reduction, no care for driveability/idle quality/idle vacuum/etc. that and I just couldn't allow myself to put a small cam in it.
theyre just on it when it sits for extended periods of time. these are whats on it now:
Old 01-28-2009, 12:00 AM
speed_demon24's Avatar
Are you going to get a chance to dyno it? It should be interesting to see where it peaks and if it hits its peak yet within the limits of the stock pcm. Hopefully it performs well for you.
Old 01-28-2009, 12:03 AM
zigroid's Avatar
the car will be dynod. I could actually go this saturday but I think its too soon. I still have some stuff I need to do. ed curtis said it should peak around 6600 rpm.
Old 01-28-2009, 12:24 AM
fergymoto's Avatar
^I bet it won't. Post up when you find out though!
Old 01-28-2009, 12:53 AM
riceburnerZ28's Avatar
Not bad !
Old 01-28-2009, 02:15 AM
robsquikz28's Avatar
very nice man
Old 01-28-2009, 07:05 AM
BOLO's Avatar
Sounds awesome. That size cam will welcome a 4.10 gear and a 4000 stall combo. Congrats and enjoy.
Old 01-28-2009, 09:51 AM
Green3spd's Avatar
Sounds really good! Cant wait to see it on the track with 4.10s and 4k stall!
Vids ASAP!
Old 01-28-2009, 10:16 AM
zigroid's Avatar
haha the car is covered with 6" of snow right now and has a donut on the front drivers side wheel so it isnt gonna be moving for some time lol
Old 01-28-2009, 10:19 AM
Elliott's94Z's Avatar
Sounds awesome! I demand a bigger burn out next time
Old 01-28-2009, 10:20 AM
zigroid's Avatar
I was a bit skeptical too. I was going to spec my own cam and I was debating between a 230/236 or a 236/242. my valvetrain is set up so that I could really stick a lot of cams in there without changing much. if worse comes to worse Ill just swap a cam out. that will be easy compared to what I just went through with the car
oh and I see you're from sharpsville. I believe I played you guys in highschool football.
Old 01-28-2009, 10:31 AM
95 Formula's Avatar
you should be able to hit your goal pretty easy with that setup. A budy of mine hit 11.2s with stock bottom end, ported stock heads, 4800 stall and a cam just a tad bigger than yours..he did it with 3.83 gears and it was under geared. Good luck with your setup and it sounds great.
I agree on the drivability of these cars with cams most people are afraid of. I drove my car on the street for a long time with a 255/263 mid 600 lift and it drive just fine with a 6 speed. Have fun with the car man.
Old 01-28-2009, 01:02 PM
In-Zane Moderator
ZONES89RS's Avatar
Sounds great, let us know ow it zings on the big end.
Old 01-28-2009, 01:10 PM
zigroid's Avatar
thanks for the reassurance. I have had a lot of people say my goal isn't attainable. with a good enough launch you only need to trap 110-111 to get in to the 11s. I think I can do it.
I honestly thought my driveability would have been really bad especially with the 2.73s but I was surprised.
heres how the car sits as of about an hour ago:
it sucked when I saw it sitting there for 2 years without an engine. its downright painful knowing it runs and not being able to drive it lol
Old 01-28-2009, 01:32 PM
TABBED 5.3's Avatar
You shouldn't have any problems. I'm running a 236/242 in a car set-up similar to yours although I still have all stock suspension and ran a 7.86 in the 1/8th with a soft 60ft. This was the first time at the track with the new cam, still running 1.5 rockers. BTW that time is SUPPOSEDLY a 12.2 in the 1/4 so whatever thats worth to you hahaha.
Quick Reply: vid: 242/250 112lsa in a 350
