need alittle help on my idle ?
hi all,
well it just happen last nite but when I come to a full stop the rpm goes real low like it wants to die but then goes back up?
mine has been doing the same thing the past few days. it will be at about 900 then fall to about 6 then go back up to 900 then go back to 600 but then when the car warms up it stops doing it. I dont think i have any vacuum leaks and my maf is clean.
"The important thing to keep in mind about vacuum leaks is that they have the most noticeable effect at idle. At part and full throttle, more air is entering the engine through the throttle opening so a vacuum leak has less effect on the air/fuel ratio"
This is from a website that may help you a great deal in troubleshooting your problem-check it out and let us know!
http://www.aa1car.com/random-misfire/
