Will a carb run OK on a LTx cam?
Old 01-28-2009, 04:06 PM
Formula350's Avatar
Default Will a carb run OK on a LTx cam?
We stuffed a B-Body cam into this 350 that we were going to TBI for an S10, but my buddy is having second thoughts on actually using TBI due to having to have a chip burned for it. He has an ECM with an upgraded chip, but sadly he has no clue about it since it came in a car.
Anyways, so he's thinking it might just be better, and easier, to just carb the thing. Yet I thought I read somewhere that there's an issue using a fuelie cam with a carb, due to it's duration or overlap, something :\
Anyone have any idea if that's actually the case or not?
Thanks.
Old 01-28-2009, 04:11 PM
96lt1m6's Avatar
sure will,it could run alot better with a cam with more duration though...
try it with the tbi first to see if the calibration will work ok with the cam then if not swap it to the carb
Old 01-28-2009, 04:19 PM
Formula350's Avatar
Suppose we could, since the 4.3 TBI harness in the truck as it sits will hook right up to the 350.
Ugh I just remembered we still need to get some better valve springs for it :\ heh That B-Body cam just squashes those stock TBI ones (Sorry to you few who were going to hook me up cheap, my friend forgot all about it, and funds are tight)
Old 01-29-2009, 08:41 PM
SLawson86's Avatar
dude if your looking for valve springs, ive got my stock ones ill give you if you want to pay shipping.
Quick Reply: Will a carb run OK on a LTx cam?
