Centri Superchargers... max psi?
i know that most of you guys run low boost 5-8psi on your engines. i noticed on the ATI website that the p1sc1 can push 32psi max. i know i can just go turbo and push that much easy. anybody ever taken any centri to about 28psi? or that even possible. let me know whats up. thanks
im talking about the head unit itself. is it possible to push 28psi out of one? thats what im looking at here. i know you guys know a lil more about centris than my community
8 sec potential, 12 sec slip
I got 14psi from my P1SC on my 346 with stock truck heads. That was spinning the P1SC to like 98% of its max RPM. You wont ever see 30psi on a V8 from a P1SC. It may make that much boost on a 4 banger tho. As has already been mentioned here, the boost# by itself is useless. It will depend on the engine combination such as cam, compression, and the biggest factor would be displacement. Had I been running the exact same pulleys on my P1SC on a 427 it would have made wayyyy less than 14psi. Its all relative.
