Susp. upgrade???
Susp. upgrade???
I've got a 96 LT1 M6 car that needs new shocks and struts. While I'm replacing them I might as well go with a slight drop, a good brand, and whats the best deal. Any Suggestion on brand, drop, and price?
I'm willin to bet you want autocross.
I'm going to get a set of konis, with strano springs and strano sway bars.
this is how I ran me Trans am when I first got it. I know it looks good and handles great.
While I'm in their ill prolly go ahead and do some lower control arms and adjustable panhard
That's what id do.
If you want a strip setup, its even easier, get some qa1's and take the front swaybar off.
That's what id do.
That's what id do.
That's what id do.
I've got the Strano/Koni setup on my Trans Am. If you plan on going with the full setup - springs, shocks, SFCs, LCAs, LCA relocation brackets, PHB, Sway bars, etc. figure on spending 2K+. I have everything minus the sway bars and I've sunk around $1600 into it. (Not counting any install costs)
I am wanting a great handleing car that still does alright at the strip. It is a daily driver and not a all out drag car. I had a friend who had a lt1 Z that had eibach springs and I don't know if it was that he didn't change shocks and struts but handling was aweful and almost dangerous to drive. If it is that he just needed to replace shocks and struts then I'll go with them. I do appreciate everyones input on this... I'm gonna check some prices and go from there.
Strano springs for sure. I don't know what your plans are as far as shocks go, but if you are going to lower it stock replacements won't work very well. You might have already known that, but just thought I'd note it in case. Konis are worth the cash if you can pull it together, but if not the KYB AGXs are still a very nice step up
