Wide rubber on stockers?
Old 01-30-2009, 12:07 PM
oddwraith's Avatar
Default Wide rubber on stockers?
Just wondering if anyone knows off hand what the widest rubber could be to place on my 17x9 rims? I have 275's now, can I go wider? Just wondering.
oddwraith is offline
Old 01-30-2009, 12:13 PM
disc0monkey's Avatar
disc0monkey is offline
Old 01-30-2009, 01:15 PM
SOM02WS6's Avatar
295 is the biggest you should go, I know people run 315 nitto's but you shouldn't because it is too much tire for a stock rim because it will fit but it will be proper...
SOM02WS6 is offline
Old 01-30-2009, 01:20 PM
hj99Z's Avatar
I would stick with 295 or lower
hj99Z is offline
Old 01-30-2009, 01:34 PM
Mean87SS's Avatar
Originally Posted by blk/slvr02ss
315/35/17 NITTO Drag radial's fit well because they are smaller than a street tire in that size.
They are not safe. They should be on an 11" rim.
Mean87SS is offline
Old 01-30-2009, 03:27 PM
fordeater's Avatar
BS how are they not safe? cause nitto recommends it...Does GM recommend grinding our calipers to clear 15" wheels. I have been working with tires for over 3 years and it is not unsafe, they will just wear irregularly.
fordeater is offline
Old 01-30-2009, 04:01 PM
ItsNotStock's Avatar
I would not recommend putting 315's on a stock rim. This thread reminds me of another one on SVTPerf.
OP:Would you like me to take you a picture of 11 inch wide tires compared to the stock rim to give you an idea of why it is a bad idea?
ItsNotStock is offline
Old 01-30-2009, 04:10 PM
Customizing Director
MadIceV8's Avatar
275 is the widest you can safely put on a 9" wheel. There are TWO sticky's on the top that explain your question.
fordeater - Nitto does not recommend it.
https://ls1tech.com/forums/wheels-ti...-5-wheels.html
MadIceV8 is offline
