Iceman can
01-30-2009, 07:33 PM
Where is there, if there is one, a fuse for the cruise control? Mine went out and I can't find a reason why.
Z Fury
01-30-2009, 10:18 PM
Manual or automatic? If manual, have you recently had clutch work done?
Iceman can
01-31-2009, 03:35 AM
Automatic. Happened after headers went in
wht01ws6ta
01-31-2009, 01:40 PM
Not to be a smartass but look in the manual for the fuse location. Or, look on the fuse block because they are labeled. Should be AC/Cruise 15 Amp but not sure if that is the problem. When mine stopped working it was the switch on the clutch. There is one for the brake as well of course.
