cc306 question
Old 01-31-2009, 11:44 AM
lt1_2buku's Avatar
Default cc306 question
I have two questions about the cc306. I have a 383 with a baby cam from nu-tek. I wanted to go a little bigger and found a deal on a cc306 out of a 94 camaro. When I got the baby cam, I remember them talking about it having to be a small base circle cam. My first question is would this cc306 cam out of a 94 fit in a 97 and my second are all the cc306 cams small base or is that something you would have to special order?
Old 02-02-2009, 07:48 AM
DAVE00's Avatar
Not sure about the small base, but I do know that the 95+ LT1's have a longer dowl pin in the cam for the Vented opti that the 94 doesn't have.
Old 02-02-2009, 09:54 AM
fmaznicki's Avatar
the dowel can be changed on any cam
Old 02-02-2009, 11:43 AM
ss.slp.ls1's Avatar
I'd think that it won't work. You can give Comp Cams a call and have them look up your grind number and see if it will have any clearance issues in a 383. Even if you got an all clear, you would still have to install it and see if there are any clearance issues with the rods or crank. I would order a special small base circle grind. Better peace of mind.
Old 02-02-2009, 09:47 PM
myltwon's Avatar
cc306 is not small base circle unless you custom order it that way
just get a custom cam
Old 02-05-2009, 08:40 PM
lt1_2buku's Avatar
Has anyone put an off the shelf cc306 into a 383? If so how was the fit?
Old 02-05-2009, 09:02 PM
1badzee's Avatar
idk but i have a brand new one for sale $180 shipped
Old 02-05-2009, 09:48 PM
Ihasfip's Avatar
I am pretty sure this guy I know has a CC306 (off the shelf) cam in his 383. Not positive though, definately worth looking into.
D
Old 02-05-2009, 10:11 PM
connexion2005's Avatar
I ran the cc306 in my 383. Trapped 115 on stock tune, stock heads and stock throttle body with 3.23 gears in a 6 speed. This was an Eagle bottom end with 5.7 I beam rods and ARP bolts. The assembly was good for up to .600 lift according to the manufacturer.
Old 02-05-2009, 10:45 PM
lt1_2buku's Avatar
was it straight off the shelf or did you order small base circle?
Old 02-06-2009, 07:15 AM
Mattsz28's Avatar
My car is running a cc306 right off the shelf in my 383. I dont think you need a small base circle to run the cam.
Quick Reply: cc306 question
