Car turned a code
Old 01-31-2009, 12:07 PM
barney1golf's Avatar
Default Car turned a code
Car has been sitting all winter except for the 2 week start up and run till it gets up to temp all the way. The last time it turned a SES code. Had it checked P0400 EGR air flow malfunction. What needs to be done?
Old 02-01-2009, 07:08 PM
All I was wondering if a new EGR would fix this problem. Thanks for all the help.
Old 02-01-2009, 07:14 PM
shbox's Avatar
Maybe, maybe not. If the valve is not working due to the diaphragm leaking, then you would need a new valve. If the passages are just clogged up, you need to unclog them.
