TCC in 3rd/4th gear
TCC in 3rd/4th gear
Is there an easy "hard-wire" way to disable converter lock-up for cruising around town? I have a 2000 TA w/ a few bolt-ons and a TransGo shift kit and Yank 3600ss. When cruising around town with stop and go traffic(40mph and below), converter will drop into TCC. This has become annoying. Is there a transmission or PCM comm. wire that can be interrupted for town cruising but then reconnected for High-way TCC without throwing a code when cruising? I thinking maybe a toggle switch to interrupt/and reconnect. I have no tune shops close and I am hoping to do this as a temp fix until I find time to take a trip to the city for a tune. Any other suggestions/comments. Transmission works/shifts good otherwise!
Thanks
Thanks
The brake interrupt switch at the brake light switch had good results. My additional inline switch breaks continuity of the brake signal to the trans.The only problem I found was the transmission has to go through all gears then TCC before the computer will accept the input (or lack of). Once the trans hits TCC, cycling the switch will drop the trans out of TCC and prevent TCC until an ignition reset or activation of switch (reconnecting signal to trans). This will work for now until we get the computer reprogrammed. Thanks everyone.
I was also thinking of wiring a switch, I can tune the TCC apply and release, but there is no perfect tune.
I can tune TCC to work perfect until I'm stuck for 20 miles behind some old lady who wants to cruise at 1 mph below my lock up speed.
I may try adding a performance mode switch to PCM pin J1-71 and tune it just for TCC apply options.
I was thinking of using a pin off my now disconnected rear O2 connector, plugging it into 71, cutting it out of the plug and it'll reach to under the console. I'd copy and paste all of my existing tables over and a modified tcc table so when I hit the button it only changes tcc apply (or whatever else I program in different than stock).
