6.0 truck engine build?
Guys, I am building a 6.0 cast iron truck block to put in my truck. Does anyone know if there are any hyperueretic oversize pistons for the 4.00 bore that are flat tops. Like a 4.03 LQ9 or LS2 replacement piston. Thanks
This is an LQ4 pullout build. I had purchased LQ9 rods and pistons. I am boring to 4.03 and wanted to use the LQ9 rods and replacement flat top 4.030 pistons. I don't need expensive forged pistons because this motor will only be 10.9 to 1 compression and naturally aspirated running a 226/228 585/588 114+4 cam and going in the truck. Thanks.
SEALED POWER Part # H1129CT come in STD, .020 -.50mm, .030 -.75mm
he posted a Pic on page 6 about 1/2 way down. Here is the link...
http://www.performancetrucks.net/for...=431599&page=6
Is that on the truck part of LS1 tech or the LS1 truck forum? If I could bore my cast block to 4.030 and use the LQ9 rods with 4.030 hyperpuretic pistons, that is want I want to do. I have a set of Patriot stage 3 heads with 2.08/1.60 valves and a vengeance VRX3 cam to put in it. That would be fine for my 2005 RCSB Z71 truck and probably be a good naturally aspirated budget build.
Here this is the specific post with the picture. You will probally need to login over there first before you can see the picture
http://www.performancetrucks.net/for...2&postcount=60
