Just updated the top end on my LS2 427
Old 02-01-2009, 10:08 PM
jason99frc's Avatar
Default Just updated the top end on my LS2 427
LS2 BASED 427 swapped out my PRC 2.5 HEADS, FAST 90 AND 248/254 .601/.610 114+4 CAM ( MADE 507 RWHP) for
TSP LS7 Heads w/ new TSP .700 lift spring kit, Ragin Racin ported LS7 intake, New Rectangular port specific Comp LSL lobe 251/267 .660 115 cam
Made 570 rwhp
Peak was only up 62 but @ 7200 rpm's im up ~ 100 rwhp & 70 rwtq
Found 2 issues during/after the dyno runs:
1. I Realized after the pulls that my twin cutouts were only open ~ 25% , Switch went bad and I wasn't in the car so didn't notice the sound difference. Dyno room is like an echo chamber so from out side its hard to tell. I run a stock TI exhaust and with the old setup I gained 38RWHP closed vs 100% open. Will know tomorrow how much 25% - 100% is worth on the new setup.
2. Running out of air, KPA was dropping from 100 to 95, removed filter from Vararam and drop was reduced to 97 - Going to Look @ MAF / Air intake options options after a few runs with the cutouts fixed on Monday.
Cutouts are now fixed and waiting to determine best big MAF route after a few more pulls w/ cutouts 100% open. Curious if the exhaust was limiting flow and causing any of the MAP sensor drop.
Old 02-01-2009, 10:11 PM
LS1 Tech Administrator
Patrick G's Avatar
Nice gains. Post up the graphs when you get a chance. I'd love to see your power in the mid-range.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 02-01-2009, 10:24 PM
jason99frc's Avatar
Once I get the issues resolved I will.
BTW - I sent you an PM a few months back to talk about the cam but I couldn't catch-up with you. I thought maybe you didn't remember me from the early days with our pal Mike Senia. Each of us testing 3 different converters a month. When I was working with Dave Inall developing the F body Twin Turbo kit on my old car "Fast Orange", Hell over 8 years ago now.
FYI - Mid range is a little soft but I race on the skreet mostly and the car weighs ~3050 so i didn't need/want a lot of mid range torque. I run 4.10 gears, so I leave easy, hit it, stick it in 2nd and I stay @ 5500+ from there on.
Old 02-02-2009, 05:06 AM
01SOMm6's Avatar
Nice numbers Jason.
Its Bryan From OC, I guess I ran you on your OLD Setup. I bet that thing moves out now.
Old 02-02-2009, 11:35 AM
allngn_c5's Avatar
Sounds like your topend got a major boost. When you have everything done could you post an overlay of your old setup vs the new one so everyone can get a good look at what your new setup does in comparison to the old one ?? Nice results bro. I hope you crack the 600 rwhp level with the 100 mm MAF. Best of luck.
Old 02-02-2009, 11:56 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Nice numbers! Let's see a graph when you get a chance!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 02-02-2009, 05:18 PM
03 BUSA's Avatar
Great numbers. Why such a huge gain? Were those heads too small for the 427? The cam and intake seemed about right. Not real familiar with the 2.5 heads. The old numbers seemed low and now they are spot on that is why I was asking just curious.
Old 02-02-2009, 06:03 PM
jason99frc's Avatar
03 Busa,
The LS6 heads w/ the prc 2.5 port and valve job were a restriction before + the fast 90 wasn't ported and no UD pulley. I'm sure that caused the old numbers too be a little lower which in turn makes the changes look even greater especially @ the higher RPM's.
****update****
Cut outs open to 100% made zero difference. I guess the extra opening just makes it louder.
Deciding now on whether or not to do the 100mm Maf or just leave it alone @ 570RWHP
Old 02-02-2009, 07:25 PM
no title here
skyhighsami's Avatar
On your 427 cube LS2 I am guessing this motor wouldn't handle much spray because of the piston deck having to be so thin right? I am wanting to possibly build either a 427 or 454 but I would lke to be able to spray it and TSP says some of their motors the pistons get to thin for the added temp of spray.
Old 02-02-2009, 08:34 PM
raymond mckinney's Avatar
Good numbers, I'd like to see the graph.
Old 02-02-2009, 10:22 PM
NVR4GET's Avatar
The motor will handle plenty of spray, I have a ls2 427 in my car and am spraying a 300shot with no problem. They sleeve the block its not just bored.
Matt
Old 02-03-2009, 09:51 PM
jason99frc's Avatar
shyhighsami,
I cant speak for your engine but my setup had a 200 shot on it sometime ago and everything was fine but that doesnt mean that yours will????
If TSP built your engine I would listen to what they say. They may have put it together with a total NA application in mind and there can be different parts spec'd , anyway if they built it they should know.......
Old 02-04-2009, 11:26 AM
jason99frc's Avatar
xxxxx
Old 02-04-2009, 11:51 AM
jason99frc's Avatar
xxxxx
Old 02-09-2009, 09:25 AM
10secondZ's Avatar
Wow Jason!
Hell of a good gain Any updates on a bigger maf or an SD tune? Does the car feel stronger in the mid-high range on the street?
Carter
Old 02-09-2009, 10:35 AM
LS1TECH Sponsor
Ryne @ CMS's Avatar
with camshaft i would definitely try to run it sd, or if you are dead set on running a maf, rewire and run the ls7 maf, just my 2 cents
Old 02-09-2009, 11:31 AM
PewterScreaminMach's Avatar
Wow, impressive gains. Can't wait to see the graph.
