Western Members CA, AZ, NV, UT, CO, NM, HI
power steering reservoir leak/seep around cap.
Old 02-01-2009, 10:49 PM
chevystyle's Avatar
Default power steering reservoir leak/seep around cap.
After cleaning around he cap, within a week, it's wet again, like the fluid is seeping out slowly. It does get low on fluid. Any ideas why it my be leaking/seeping?? It's not a bad leak at all. It kinda dries before it gets to the bottom of the reservoir. Thanks.
Old 02-01-2009, 10:52 PM
Soul TKR's Avatar
mine kinda does this as well... haven't figured it out yet...
Old 02-02-2009, 09:53 AM
DavidH426's Avatar
My Camaro SS did the same just change the orange "O" ring.
Old 02-02-2009, 11:00 AM
hlaalu's Avatar
mine did that. i poured some of that stop leak crap and it worked
Old 02-02-2009, 01:05 PM
ROCNDAV's Avatar
Mine is doing that too. I believe thats what is messing with my alternator.
So hlaalu, did that stop leak really work?
Old 02-02-2009, 01:13 PM
disavowed10's Avatar
mine did the same.. the rack n pinion boot has a small hole and would leak slowly and i would put too much fluid and it would over flow.. which then messed up my alternator..
Old 02-02-2009, 03:27 PM
hlaalu's Avatar
yea mine was leaking really bad, destroyed one of my alternators, so i figured what the heck. the bottle of stuff was like 5 bucks. worth a shot
Old 02-02-2009, 04:07 PM
Soul TKR's Avatar
my alternator is covered in PS fluid... still working strong though... kinda weird.
I need to find a place where I can put the car up on a lift and steam clean the underside to get all that oil residue off of everything... just can't find one
Old 02-02-2009, 04:09 PM
hlaalu's Avatar
i have one of those black and decker power washers, works pretty well doing that.
i wonder if anyone makes a cover or spill guard to protect the alt from fluid?
Old 02-02-2009, 04:11 PM
ROCNDAV's Avatar
I was thinking that very same thing this weekend. I should fabricate some sheet metal, then I thought, nah I should just fix the efing power steering pump!
Old 02-02-2009, 04:14 PM
hlaalu's Avatar
lol ya i was thinking the same thing with the sheet metal, just too lazy to get in there and figure it out
Old 02-02-2009, 04:22 PM
ROCNDAV's Avatar
Same here. Plus the washing machine broke so I had to get the car out of the garage and figure out what the eff was wrong with the washer. Ended up spending the whole weekend working on that. :/
Old 02-03-2009, 12:15 AM
ae13291's Avatar
mine does the same. there is a slight crack around the cap on mine around the edges and it leaks slowly. but i always keep my fluid a little lower because the ls1 PS pumps expand the fluid alot
Quick Reply: power steering reservoir leak/seep around cap.
