Compresstion question!!
I have built 346ci with 72cc Heads the compresstion is around 8:5.1 with stock sized head gasket now I'm thinking about going with 57cc heads from TSP with a thiner head gasket for 11+ compresstion is that possible???
Does anybody have any idea what my compresstion will be???
Thanks.
Thanks.
Thanks.
Thanks.
If you mean compression here are two online calculators that might help:
http://www.c5frc.com/calculators/Com...Calculator.htm
http://www.rbracing-rsr.com/compstaticcalc.html
LS1Tech Premium Sponsor
Are your pistons true flat-tops, or do they have valve relief or dish? If so, how many cc is the relief or dish? With a true flat-top like the OE piston, you'd have over 12:1 with a .040" and 57cc chamber!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I'm gonna hi-jack for a second.
Matt, I have one of your forged 347's with Diamond pistons. I have stock replacement Fel Pro head gaskets and a set of stock LS2 heads. What would my compression be?
What cc are the pistons? What compressed thickness is that gasket?
__________________
