QUICK NEED PART #'s!!!!
I need the factory GM part numbers for the Crank Bolt and LS2 Timing Chain set with chain and the gears.
I need these ASAP.
I have a 00 WS6 which is what these items will be going on.
Thanks,
Evan
I need these ASAP.
Thanks,
Evan
LS1Tech Premium Sponsor
Bolt = 12557840
Chain = 12586482
Top Gear = 12576407
Lower Gear = 12556582
Chain = 12586482
Top Gear = 12576407
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
What do you need the link for if you already have the part numbers from this thread??
__________________
