low oil light
The low oil light is supposed to come on when you're about 2 quarts low. In your case it's probably the sensor or wiring. It screws into the side of the oil pan.
Good question, don't know if it's configured to work like the low coolent sensors were. I'd replace it if it's bad, used to be about $50 at the dealership, but should be cheaper from a local parts store. Take a look at the connector and wiring harness.
yea i recently broke my oil pressure sending unit since its right above the oil filter got one from autozone for like 30 bux if u disconnect it ur check gauges light will show and u will not know if ur gas light is on since ur check gauges is ur gas light
my low oil light has been on for a while and i have tried to unplug connectors to make it go away but nothing...comes on goes. i did however unplug my low coolant plug and that light went away. bottom line----my cheap *** needs to buy some sensors.
one of my wires was damaged i noticed while doing a stall install and i forgot to fix it and the next day the light came on. the wire looked kinda chewed up. i fixed it and havent had a problem since. its on the pass side btw.
