Resized from FIC
Old 02-02-2009, 08:29 PM
jetlag's Avatar
Default Resized from FIC
How many people on here are using resized injectors from FIC? What were the results? What size did you change? etc.
Old 02-02-2009, 10:35 PM
FICINJECTORS's Avatar
here is a few tuners that use our injectors and have installed many sets. you are free to call them and ask them how they work
Jim Moran Speed Inc. in Schaumburg Il
http://www.ls1speed.com/
Ryan Injected Engineering Kennasaw Ga
http://www.injectedengineering.com/
Chris Harwood Xtreme Motorsports Florida
http://www.motorsportsxtreme.com/contacts.aspx
Old 02-02-2009, 11:42 PM
405HP_Z06's Avatar
Originally Posted by ls2nut
i have 48 made from my stock ls2 34. All I had to do was change my IFR table and it ran perfect. My brother has 42's for his 5.3 Yukon. Work great also. There is a guy on c6 that just did a write up.and video. here is the link
http://forums.corvetteforum.com/c6-t...t-service.html
Great read! I shipped my Bosch Design III 36 lb/hr injectors in for FIC's restoration service and received them back today. All parts replaced and they flow within .3% of each other. Props for an awesome forum vendor.
Old 02-03-2009, 05:18 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I'm looking at having this done at some point. I have a new build in mind that is going to need some larger injectors. Is the pricing for modifying them the same? Example: Are modifiying the same injector to a 48 lb / hour versus a 72 lb / hour the same price?
Old 02-03-2009, 06:14 PM
its 30 per injector including a rebuild, new o rings filters, caps, plus they are flow matched, this is the same for any injector. Remember, not all injectors can be modified. PM with you application and type of injector
Old 02-03-2009, 08:04 PM
KAMEDTA's Avatar
i ordered a set of ls2 made to 48 today from them great customer service thanks fic
Quick Reply: Resized from FIC
