what th350 bolts to LT1?
Closed ex-Sponsor Account
Just about any T350 will work from a Chevy engine. There are lock up converter after 1979 and also some from 6 cylinder engines that may have reduced clutch plates. They are easy enough to update so just find a Chevy bolt pattern 350 and decide if you want a locking or non non locking (choose the non!!!). Then go from there.
You're saying LT1 thats an engine, how do we know what car?
Now about that TA mount....assuming you know already? Assuming it's an f-body.
Get a B&M or TCI adapter that bolts to the extension housing for the TA to mount to. Or get a more expensive tunnel mounted TA mount.
If you get a 9" tail th350 you can reuse your driveshaft. If you get the short one you'll need a longer driveshaft.
IIRC the early 4th gens (or 3rd gens) had different mount holes for the crossmember.
You're going to need to move the crossmember.
