anyone use theses injectors Lucas New 621037
i just bought a set of Lucas New 621037..here is what it said on the web site
Static Flow Rate: 37.27 lb/hr (+/-4%)
Dynamic Flow @ 2.5ms PW @ 100Hz: 8.42 mg/pulse (+/-6%)
Coil Resistance: 15.9 Ohms (+/-0.35 Ohms) (This high-impedance injector will work with all factory ECM/PCM injector drivers)
Spray Pattern: Split 20o (+/-4o) >65% of delivery within 10 degrees
Physical Dimensions: EV1 Body Type
Connector: Minitimer (Bosch EV1)
i was told that these where 42lb injectors at our fuel pressure. im thinking these should be fine for my 402cid with trick flow heads and 11.1 compression..let me know what you think..
