Custom Switch Panel
Old 02-03-2009, 05:14 PM
69BirdX's Avatar
Default Custom Switch Panel
Installed my line locks on sat. I went with the Sjm kit. Thanks Install went pretty smooth except that i put the solenoid on backwards. But here is pics of the custom switch panel i made at work. Its alittle scratched from the install but its more of a test part. I gonna make a nicer one and gonna get it anodized black and laser engrave it. Let me know what you think
Old 02-03-2009, 06:59 PM
firehawk#682's Avatar
thats thick!
Old 02-03-2009, 07:16 PM
2000_SS's Avatar
looks great, nice work.
Old 02-04-2009, 02:00 AM
69BirdX's Avatar
thanks
Old 02-04-2009, 02:03 AM
jetlag's Avatar
I think it needs better looking switches, but good work!
Old 02-04-2009, 06:46 AM
69BirdX's Avatar
I agree but thats what the kit came with ill prob change them up once i make a nicer one
Old 02-04-2009, 07:36 AM
toothdoc's Avatar
How hard of an install is a line lock?
Old 02-04-2009, 09:34 AM
alanw6's Avatar
Is the piece that thick all the way through, or did you pocket the back side?
Old 02-04-2009, 03:39 PM
69BirdX's Avatar
The hardest part was bleeding the system
Its pocketed on the back side. Its less then a half inch thick. I Think i measured it at .436 thousandths and then pockets it to about .200 thousandths. I made it -.001 under so it would just fit snug in the dash. I wanted it thick so i dont have to worry about it popping out. The next one i make will be thinner.
Old 02-04-2009, 03:46 PM
hlaalu's Avatar
that looks really good!
Old 02-04-2009, 05:39 PM
alanw6's Avatar
Thanks for the answer. I figured it had to be for the switches to mount correctly, but thought maybe you had done some larger counterbores on the back side. The pocket is how I would have done it, also.
I like the face milled finish on the front, too. Was this milled manually, or CNC?
Old 02-04-2009, 07:30 PM
69BirdX's Avatar
CNC. I used a shell mill did the top then with a 3/8 Endmill did the countour. Then engaving. After that I flipped and slugged off the excess. Since i was only making the one part i just did the pocket manualy to where i needed it for the switches. My next one will be all CNC since i pretty much have it programed
Quick Reply: Custom Switch Panel
