Converter not locking
Old 02-03-2009, 07:23 PM
aboatguy's Avatar
Default Converter not locking
Converter is not locking scans/datalog show no codes looks like converter should lock but slip rpm high. Is it tranny or converter?
Seems like it should be locked here.
[IMG][/IMG]
Just to show that the brake switch/engaged and enabled circuits change
Old 02-03-2009, 08:14 PM
LS1Tech Sponsor
performabuilt's Avatar
Could be any of several things, Converter, Input shaft oring. TCC valve, PWM solenoid, Converter control valve.
Gonna be a little bit of a which hunt to find out.
Is this the 95 C4 ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 02-03-2009, 09:19 PM
Moderator
jimmyblue's Avatar
At light cruise, even 100% TCC duty only gives you
100% of bare minimum main line pressure on stock
LS1 tunes. Dunno about LT1 setups, but you ought
to have a look at the commanded line pressure or
force motor current. Smaller diameter converters
with a standard size clutch, need all the help they
can get.
That sort of road speed and TPS was where I had
all kind of slip trouble on my old converter. Barely
got it drivable with a bunch of tune fiddling but the
clutch was just too wimpy. Needed a lot more line
at light loads, to keep it locked.
Is this a new problem or been going on for a while
(like, since converter break-in)?
Old 02-04-2009, 07:55 PM
aboatguy's Avatar
Is this the 95 C4 ?
Yes, its the C4 converter used to lock. It quit I installed a transgo which should take the PWM out of the equation NO CHANGE.
Here's a shot prior to Shift kit
Old 02-04-2009, 07:57 PM
aboatguy's Avatar
can get.
The converter is a couple of years old and it used to lock
I do shift a little higher than stock
It started with a slight vibration at around 80mph thats steadily gotten worse. However, I thought I had torque converter issues due to a shudder under moderate high speed acceleration. Then I datalogged and noticed that the slip rpm graph is all jagged when it used to be straight as an arrow at speed.
I have a noise when I shut the car off that I thought was one of the electric fans spinning down (rattling sound like the fan was spinning down with bad bearing) but after laying under car with it running and having my kid shut it off it was coming from under converter cover. I pulled the cover same noise. I pulled converter started car shut it down noise went away.
Mike
Old 02-04-2009, 08:06 PM
LS1Tech Sponsor
If it quit when you did the transgo you have miss assembled the ISO valve they give.
__________________
Call 888-744-6542
Old 02-04-2009, 08:27 PM
aboatguy's Avatar
I bought the transgo kit prior to TCC not locking, it quit locking well before the install. I wasn't going to install the kit until I found the problem; but I was told that the transgo may fix it, so I installed it and no change.
Summary
(Noise and no lock prior to transgo) or transgo install made NO DIFFERENCE.
Old 02-06-2009, 06:08 PM
aboatguy's Avatar
Help!
Old 02-06-2009, 06:44 PM
LS1Tech Sponsor
oK I miss understood
well that leaves TCC valve stuck , missing or damaged input shaft oring or converter I am afriad
__________________
Call 888-744-6542
Old 02-06-2009, 06:53 PM
deadhorse66's Avatar
I've seen the TCC apply valve wear out in these a lot too. Only fix is to replace the valve body. Have you tried to command it full on?
Old 02-06-2009, 07:26 PM
aboatguy's Avatar
How do you command full on?
Old 02-06-2009, 07:34 PM
aboatguy's Avatar
Is there an easy way to check for (or fix stuck TCC valve?) can input shaft O-ring be replaced during converter replacement?
.....or do I need a full tear down. Tranny works fine with the exception of lock up.
MIke
Old 02-06-2009, 09:05 PM
LS1Tech Sponsor
The TCC valve can be checked by removing the TCC solenoid the valves right above it,
The oring can and really should be replaced during converter replacement
__________________
Call 888-744-6542
Old 02-06-2009, 09:21 PM
aboatguy's Avatar
I appreciate the help. OK so I pull the TCC solenoid, what do I do to ensure the the TCC valve is operational?
Old 02-06-2009, 09:42 PM
LS1Tech Sponsor
well you will see a little cove it partially covers the valvve. But you will see the valve. Take something like and ice pick and push up and stroke the valve up and down
But now I also had a guy the other nightwho installed a TG2 and used the ISO valve and had no lockup after it , In his case I had him reinstall his factory valve and modify it and he had lockup with pwm COMPLETELY ELIMINATED .
__________________
Call 888-744-6542
