will not crank even with vats turned off
my 01 trans am will not start. hooked up with laptop and turned vats off but still no start. after checking found that if u ground the yellow wire with black stripe at the starter relay the car will crank. anyone have any ideas?
Can you just turn VATS off with a laptop? I thought it still could give you a problem even if you program it out. The VATS is a two path security system right? Ignition and fuel?
I am currently bypassing my vats right now is why I asked. I have a similar problem and all of my checking so far has let me to believe as long as the problem is not in the BCM it can be bypassed rather easily.
If it is in the BCM then even bypassing the relay key curcuit will still give you a problem if I understand the system correctly.
i hooked up the laptop last night and turned the vats off but still would not start. from what i have found the pcm grounds the control circuit of the start relay but only after it verifies the trans is in park or neutral. when i run a jumper ground to the starter relay the car will start. so i guess i am going to check the neutral safety switch next.
Is the security light on or flashing? If it's VATS you can't fully program it out, the PCM is only part of it. I'd get a resistor(s) matching your key and plug it into the connector under the dash on the BCM side and see what happens. IIRC the PCM just controls the fuel enable portion.
bought i new iginition cylinder and just plugged in the portion for the vats and tried to start it with the old switch still in the column and it fired right up. now just have to install the new switch in the column.
