Which OIL will leak LESS 5W-30 or 10W-40??
Old 02-03-2009, 08:56 PM
ZSU
ZSU's Avatar
Question Which OIL will leak LESS 5W-30 or 10W-40??
My car leaks engine oil a bit much..
Should I use,
CASTROL MAGNATEC 5W-30 A1 or CASTROL MAGNATEC 10W-40 A3/B3 ??
Old 02-03-2009, 11:39 PM
BLK,97,T/A,M-6's Avatar
Rotella
Old 02-03-2009, 11:40 PM
MTBSully's Avatar
fix the leaks
Old 02-04-2009, 01:18 AM
whytryz28's Avatar
Should I use,
Find the leaks, Id just replace valve cover gaskets, oil pan gasket and check the manifold and oil sending unit.
Old 02-04-2009, 02:14 AM
robsquikz28's Avatar
yes fix the leaks but if thats the case just go with 15w40 or so
Quick Reply: Which OIL will leak LESS 5W-30 or 10W-40??
