Does my stock oil pump fit my new (TSP) LS2 crank gear?
Old 02-04-2009, 02:39 PM
1998Z28LOADED's Avatar
Default Does my stock oil pump fit my new (TSP) LS2 crank gear?
Hi guys I just bought a LS2 timing set for my LS1. Im putting it back together and Im having trouble getting the pump back on the gear. Im trying to be delicate because I dont wanna break anything. Is there only one way it goes or am I just being a sissy?
Old 02-04-2009, 02:51 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Make sure the gear is seated all the way. The gear is that set is the same part number as came on your car from the factory, just new.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 02-04-2009, 03:05 PM
LTstewy8's Avatar
So the ls2 timing chain is the exact same as the ls1 part# wise, but physically a heavier-duty chain, correct? Shouldn't gm change the last digit in the part# or something when they redesign it?
Old 02-04-2009, 03:12 PM
The bottom gear is the same, the top gear is different, and the chain is a bit beefier (although if you order a chain for an LS1, the old part number supersedes to the LS2 chain number).
That make sense?
__________________
Old 02-04-2009, 05:15 PM
Chris10an's Avatar
Sometimes you must remove some of the metal on the timing cover to make it fit. Specially if it is a double chain and a high volume oil pump.. use some grease on the oil pump bolts, to see if they hit the cover when you mount it back. Yes it Will fit.
Old 02-04-2009, 05:46 PM
LTstewy8's Avatar
That make sense?
ok I see now. I was thinking of a part# as an entire set that gm would sell to you, chain and gears. Good to know for future reference.
Old 02-04-2009, 06:46 PM
01ssreda4's Avatar
exactly what i was thinking....mine fit with no problems....
Old 02-04-2009, 10:05 PM
Thanks guys, I got it...
