Lt1 block Q's 2 bolt vs 4 bolt
Old 02-04-2009, 04:33 PM
GAKz28camaro's Avatar
Default Lt1 block Q's 2 bolt vs 4 bolt
I wanted to no around how much hp a 2 bolt main will handle??It will be boosted also...And what will a 4 bolt main will handle??
Old 02-04-2009, 04:36 PM
ss.slp.ls1's Avatar
There is a little more involved than just the mains, but I have seen a stock LT1 block handle upwards of 450rwhp, It depends on your set up, rpm range, power adder, etc. The real question is, how much power do you want to make?
Old 02-04-2009, 04:42 PM
Matt97Ta's Avatar
I made 537/650 through and automatic with the stock 2 bolt main block. i have sense had mine splayed but i plan on making a few more. Like ss said, what are your plans, because having your block splayed and 4 bolt main caps installed is a rather large explense.
Old 02-05-2009, 09:45 PM
I would like to get 500 or so...For a weekend car but still drive it 3 hours to the beach in the summer...
Old 02-05-2009, 10:00 PM
myltwon's Avatar
I don't see a 2 bolt main having problems with 500rwhp but that's just me
Old 02-05-2009, 10:29 PM
Black94Z28's Avatar
i've heard that 2 bolt blocks converted to 4 bolt blocks are actually stronger than the normal 4 bolt block. not sure if this is just a wives tale or not...
Old 02-05-2009, 11:59 PM
LT1
LT1's Avatar
Its true.
Splayed 4 bolt is much stronger.
And in my opinion would not be worth doing any other way!
Old 02-06-2009, 12:03 AM
89IROC's Avatar
+1 splayed 2 bolt beats the hell outta a 4bolt. my buddy looked for a while for a decent priced 4 bolt but since they were all "vette" blocks everyone wanted stupid amounts of money so he just poneyed up the difference and had a 2 bolt block splayed....
Old 02-06-2009, 12:21 AM
Self-Admitted Scammer
ls2pontiac's Avatar
My 383 is going to be Callies 4-bolt splayed. Probably don't need it, but i am still up in the air whether i am going to supercharge it in the future, so better to build it right the first time. then again, prob gonna have to pull the motor to change the compression for supercharger anyway. I beat the living **** out of my cars so i am gonna go all out and hope it holds up.
Old 02-06-2009, 12:51 AM
gregrob's Avatar
So did any stock LT1 F bodies have 4-bolt mains?
Only vettes?
Thanks
Old 02-06-2009, 07:06 AM
That's MISTER MODERATOR
Paul Bell's Avatar
A factory four bolt main block is stronger than a factory two bolt block. Corvettes came with four bolt main blocks. There have been reports that some F-body cars had four bolt main blocks towards the end of production, probably because they had more Corvette engines made than they needed.
A block with splayed four bolt mains is stronger than a factory four bolt main block. You can only have a splayed main block by tacking a two bolt block and having a machine shop do the conversion.
Other than these differences, the blocks are identical.
The strongest blocks are two bolt blocks that are converted to four bolt splayed mains with steel caps and studs.
Old 02-06-2009, 07:10 AM
z28rob18's Avatar
well put thats exactly what i had to say
Old 02-06-2009, 08:31 AM
Black94Z28's Avatar
theres the explanation i was trying to come up with. I remember with my old drag third gen, was building a 377 sbc and came across that discussion with my engine builder, ended up converting it to a 4 bolt main.
Old 02-06-2009, 10:25 AM
So i will be more then ok for what i am doin...500 hp boosted and maybe a little spay...What are 2 bolt lt1s blocks worth??
Old 02-06-2009, 11:01 AM
89IROC's Avatar
umm we picked up a long block from a firebird for 100 bucks! but u shold be able to find a block between 100-400 bucks...remember u can go with one from a caprice or whatever as long as its the 5.7 not 4.3....
Old 02-06-2009, 11:48 AM
Paul Bell's Avatar
I know on a big block, two bolt blocks are good to 500 HP with bolts, 600 when studded.
Old 02-06-2009, 12:20 PM
fergymoto's Avatar
^A 2 bolt big block will take a lot more than that. There's a lot of people running ~700hp on 2 bolt mains with stock bolts.
Old 02-06-2009, 03:30 PM
96capricemgr's Avatar
Should be stated that is only one LT block the LT4 and the 4 bolt LT1 blocks are all the same casting as the 2 bolt.
Old 02-06-2009, 04:08 PM
k0261886's Avatar
anyone have pics of a splayed 2 bolt main? I haven't ever seen it before.
Old 02-06-2009, 04:47 PM
Roadwarrior1956's Avatar
There is a picture of them in this page.
http://cgi.ebay.com/ebaymotors/ws/eB...m=180292567720
Quick Reply: Lt1 block Q's 2 bolt vs 4 bolt
