Yank
02-04-2009, 06:25 PM
This is a New Item:
We have 3 styles:
PN-LST1 fits LS1,6 and early LS2 3 bolt 180 sensor
PN-LST2 fits Late LS2 or LS3 with 4 lobe sensor 1 Bolt (COMING SOON)
PN-LST3 fits Late LS2 or LS3 with 4 lobe sensor upgrade to 3 bolt cam
GM Adjustable timing set will inc.
Crank gear,Cam gear, adjusters and LS2/LS3 HD thick link chain (ALL NEW GM PARTS).
The Cam gear has been reworked the allow the timing to be adjusted in degree steps from -7,-5,-3-1, 0, +1,+3,+5,+7 comes with all adjustment bushings
This is a must to set your cam correctly and you do not have to remove the oil pump to change the timing as it is all done on the top gear. not the case with multi position crank sprockets.
Next 2 orders will also have included at no charge 3 new GM cam bolts (On the 3 bolt style gear only)
Your choice of complete set shipped in USA $82.00 for Canada please add an extra $10.50
Will be shipped by USPS
paypal mike@converter.cc
We have 3 styles:
