Sponsor Group Purchases - BMR Pre-Spring Lowering Spring Sale!!!!
BMR Suspension
02-05-2009, 12:58 AM
BMR Lowering Springs - On Sale Now!!!
Front Lowering Springs - 4th Gen F-Body (SP002) : $99.95 per set of 2
Rear Lowering Springs - 4th Gen F-Body (SP003) : $79.95 per set of 2
Rear Lowering Springs - 3rd Gen F-Body (SP003) : $79.95 per set of 2
Complete Set - 4th Gen F-Body (SP001) : $174.95 per set of 4
Tech Specs: Front Lowering Spring (SP002)
1" drop
Working linear rate of 550 pounds per inch
The BMR spring is very streetable, but slightly aggressive.
Powdercoated red
Made from high-tensile silicon chrome steel (same material used by most NASCAR teams)
BMR springs are Proudly Made In America
Tech Specs: Rear Lowering Spring (SP003)
1" drop
Working linear rate of 170 pounds per inch
The BMR spring has an i.d. of 2-9/16" on the bottom so it will fit properly on the rear axle spring perch (o.d. of 2.5").
Weight - 7.4 pounds per spring
Powdercoated red
Please Hurry - Spring supply is limited and the sale will end when we run out of springs from this batch!!
Order by clicking here or by calling BMR at (813) 986 9302:
http://www.gnetworks.com/v4/go.gnf?s...ult&d=products (http://www.gnetworks.com/v4/go.gnf?s=bmr&product=11678&n=default&d=products)
Springs can also be ordered through an authorized BMR Distributor: http://www.bmrfabrication.com/distributors.htm (http://www.bmrfabrication.com/distributors.htm)
BMR Tech2
02-06-2009, 08:38 AM
Bump for 2/6
BMR Tech2
02-11-2009, 11:04 AM
Bump for 2/11
fastmatt98
02-11-2009, 08:48 PM
So what's the latest on the new design springs. I'm wanting to buy as soon as they come out.
BMR Tech2
02-12-2009, 09:33 AM
We are working with the freight company as we speak. Should be very soon. I will let you know as soon as i have more info.
BMR Tech2
02-16-2009, 09:42 AM
bump for 2/16
BMR Tech2
02-17-2009, 09:28 AM
TTT for 2/17
BMR Tech2
02-18-2009, 09:41 AM
Bump for 2/18
BMR Tech2
02-19-2009, 09:04 AM
Bump for 2/19
WHPLASH
02-19-2009, 10:21 AM
What about black???
If I install the springs, do I have to get lca relocation brackets and adjust my tq arm? I have BMR subframes, tq arm and lca's.
Thanks
BMR Tech2
02-20-2009, 08:28 AM
Sorry they are not available in black. For the best track performance you would need relocation brackets but if the car doesn't see the track they are not necessary. Yes i would check the pinion angle after installing the springs. If you have any other questions please let me know.
WHPLASH
02-20-2009, 11:18 AM
Do you make black anymore? Every other BMR product I have is black.
BMR Tech
02-20-2009, 12:49 PM
Sorry they are only available in Red powder coat...
WHPLASH
02-21-2009, 03:02 PM
That sucks........ really.
BMR Tech2
02-23-2009, 10:24 AM
Sorry about only offering the red color. Everyone has a different color.
