TS 233/239 & AFRs milled -.20
I have the 228R on a 114 with AFR heads milled .-20 off and I used the GM MLS stock gasket. Id like to go a little larger camshaft and im thinking of the TS 233/239 on a 113.
Will it fit and stay within my PTV safety clearance needs. Who as done it and measured.
What would be the proper size push rods. I currently use the 7.40
Tony?
Tony?
If you shaved off almost a 1/4 inch of material from those AFRs, you are screwed!
I hope you meant to say .020, either way you will need to measure this yourself to ensure it will clear. Anyone on here can say it will be fine, then you install it and damage your heads and engine. Be smart and test it out yourself to be sure.
LS1Tech Premium Sponsor
The .020" should only barely put you less p/v than a stock head with the afr 205s. I think you'll be just fine
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
