Need help with fuel cell
Old 02-06-2009, 06:18 PM
NEED MO POWA!'s Avatar
Default Need help with fuel cell
I am having a fuel cell installed in the trunk of the ctsv, however i would like to retain the stock fuel level gauge on the dash. What would i need to do to make it functional again. Thanks in advance.
Old 02-06-2009, 09:22 PM
code4's Avatar
you need a gm sending unit. the f bod guages require an odd ball ohm sending unit. not a typical 0 to 90. I would first find out what ohm you're factory guages requires.
Old 02-07-2009, 12:35 PM
so would i be able to use my stock sending unit, just relocate it into the fuel cell? I would assume it would work
Old 02-07-2009, 03:28 PM
code4's Avatar
if you can make it fit, & the float has to have full range of motion
Quick Reply: Need help with fuel cell
