wont idle
the car will start and die right after you start it if you dont give it a little gas also after you get it to idle, if you hold the gas down for a second and then let off it will die. the batt. and alt. are good they have been tested we are going to try and replace the fuel pump. also we have replaced the fuel filter and air filter, the car has a small cam i am not sure on the size. any help would be great thanks.
IAC valve causes that kind of thing too. Might not throw a code/SES light either.
