Crane Billet Lifters Preload?
What is the recommended preload for the Crane Billet Lifters. A 7.450 push rod will give me .048" preload. The next size push rod that I have is a 7.5. I found some generic Crane instructions that called for .020 to .060.
Thanks guys!
Rob
Thanks guys!
Rob
I had a set of Morels delivered that I returned. Half of the rollers rolled rough. These are not the Morels. I've been told by a good source that the Crane's are not as finicky (sp) with preload that the Morels/Lunati's are. Is .098 too much?????
Rob
Rob
According the the Crane instructions for these lifters, they recommend the following:
Here's a link to the instructions: http://www.cranecams.com/pdf/552e.pdf
For this engine application [Part No. 144536-16 and 144511-16
GM – LS SERIES GEN III & GEN IV ENGINES], extensive testing has shown .060 TO .090 lifter preload, on all Crane Cams Hydraulic Roller Lifters to provide the best power and performance, as well as, minimizing valve train noise.
