How to get rid of swirls?
I was always under the impression that clay bars just lifted dirt and other objects from your paint surface not removed scratches. You need some type of scratch remover or rubbing compound. I use Zaino. Meguiers makes some good stuff too.
Ya... After researching the clay bar will in no way help out. The Zaino stuff will take out the swirls, but its mainly fillers. But, even though its fillers Zaino claims to last up to 6 months with the right application and prep. So now, Is it worth actually removing the swirls by taking of clear coat or just use Zanios polish and wax with the fillers. I read some where that actually removing the swirls with wet sanding or somthing will comprises the paint.
Don't wetsand for just swirl marks. Today and tomorrow are warm out by me so i'm using the time to clean up my car. I only did the front bumper today, but I'm using Menzerna Super Intensive Polish on an Orange pad with a porter cable, and TropiCare swirl cutter. My bumper looks brand new now. It had a fair share of swirls and little dots, almost looked like pitting marks. Get yourself some menzerna and a buffer and do the whole car, you'll thank yourself for it.
when using Zainos (or any polish for that matter) you need to clay bar FIRST. They even reccomend it. It lifts off all surface pollutants so you're not ADDING new swirl marks. I've always clay barred before doing any polish work and had great results. Just don't EVER let the bar hit the ground. If it does you have to toss it.
Zaino Z5 Pro and Z2 Pro are paint sealants (despite being called a "polish"). Z5 Pro has some *very* slight fillers and will likely do very little for your problem...that's not really it's purpose.
Properly prep your paint, protect it with sealant/wax, and practice good maintenance techniques (ie. washing and drying) to minimize the return of swirls.
The best way to get rid of swirls is to get good with a buffer. Using a light/medium swirl remover with even a polishing pad will yield excellent results. Also using a quality polish after the compound followed by a good wax will make the finish amazing.
All of my vehicles are and have been Black for a long time... I've tried what seems like E_V_E_R_Y_T_H_I_N_G... Simple answer... Keep in ming these are machine applied... Meguiars UltraCut (#105) followed by Speed Glaze (#80) followed by a quality wax. Keep in mind, swirls ARE scratches, you don't get rid of them without an abrassive...
