which heads
which heads
whats up looking to put heads on my car GUnna go with AFR
I have a 96 z with an LT4 intake and LT4 hotcam im llooking for more low end power what afr heads do u recommend>
If you are shopping for heads I would highly recommend these guys. I've had 3 sets of heads on my car (mildly ported heads, LE2 heads, and now my current heads) and they outperformed any previous head I've had by far in every aspect. Not to mention the machine work, attention to detail, and customer service is amazing.
I know the comp afr 195 are recommended to me with my setup with my lt4intake and lt4 cam THey are pricey is there a better option that u guys recommend for around the same price?
What power goals do you have?
Who is going to be doing the work?
The hotcam can make around 325-340rwhp at the most! The AFR Comp 195 can support well over 500, so you'd be wasting a lot of money.
I'm not trying to bash the hotcam at all really, I do like it, it has it's place for sure. It's a very entry level cam for bolt-on cars, nothing more.
That cam is VERY mild. I honestly don't know why you'd even bother getting heads if you insist on running a cam that mild. The COMP AFR 195's are a serious piece. Who recommended them to you "with your setup"? I would seek advice elsewhere. The hotcam is a nice street cam that runs excellent with stock heads, and is a total waste with a head that can flow 295+cfm.
Some inexpensive ported stockers would be plenty. You can even save a ton by buying one of the used sets that pop up on the boards every once in a while.
"well im looking for more lowend power so what cam do you recommend with the afr 195s? Im not opposed to getting a new cam so im looking for your guys recommendations
Despite the fact that I have a "off the shelf" cam in my car, if you really want to make more power, and efficiently, you need to choose your cam based on heads. Whatever heads you go with, get a cam that the machinist or manufacturer recommends. There are plenty of off the shelf cam that work well, but to do it right you need to match the cam to the heads. All you're going to get here are opinions.
Well im just looking for all the experienced car guys here I just wanna get the most for my money and if thats not AFR heads than I wanna know. if there is a better set up for me let me know a new cam and different heads for the type of power im looking for
Can't really suggest anything without a budget or what you plan on doing with the car, so I'll just say hand ported AFR 227s with shaftmounts and a big solid roller with a super vic on top, controlled by a FAST system.
Yeah i totally understand This car is just for street i wont be taking to track if that helps! Thanks for helping me out guys with all my ?s
The TRULY experienced car guys here will tell you the same thing as I am.
