Backing plate T-bolts
Old 02-08-2009, 03:15 AM
jetlag's Avatar
Default Backing plate T-bolts
I saw something about this on here but couldn't find it.
Anyways, on my Moser 9", the T-bolts seem too short. With the lock washer on, the bolt does not come through the nut. With it off, there are a few threads coming through.
What is everyone doing?
Old 02-08-2009, 07:19 AM
subhumanzz's Avatar
i actually just had my axles out yesterday to replace the bearings. the bolts dont come all the way through the nut on mine either. although i dont think that they really could because the nuts are almost up against the reluctor ring (4 channel) i just put some blue locktite on there and called it a day.
Old 02-08-2009, 08:28 PM
ShevrolayZ28's Avatar
I remember being concerned about that. I ended up putting it together with Locktite and star type washers.
Mine is three channel but I still don't think there was enough clearance to use flat and lock washers. Never the less, maybe a slightly longer T-bolt would be the ticket.
Old 02-08-2009, 08:54 PM
jetlag's Avatar
Mine is 3 channel also, so I had room to get a flex head ratchet wrench in there.
Isn't red loctite stronger than blue? I used red so hopefully those things won't come loose.
Bob @ EPP should petition to Moser to start including slightly longer T-bolts!
Old 02-08-2009, 11:19 PM
Yes, the red is stronger and is more heat resistant. You might need to heat the bolt when it comes time to take it off. No biggy.
Ford Racing M-4002-B consists of eight 3/8x24x1.30" t-bolts and self locking nuts. I think the lock nuts with the big shoulder might be the way to go.
.....How long are the Moser T-bolts?
Old 02-08-2009, 11:47 PM
SuperSlow02's Avatar
If you take the Ebrake off its pointlessly easy to get them on...took me a min to figure that one out lol... I used blue loc tite on mine and have had my axles out twice and nothing ever came loose
Old 02-09-2009, 12:20 AM
jetlag's Avatar
Yeah, I had no problem tightening the bolts... I was just wondering about the washers.
Old 02-10-2009, 08:26 AM
Mine pull through the nut and about maybe 1 to 2 threads show through
Old 02-12-2009, 07:19 PM
2000TransAm24's Avatar
My t-bolts were too short also. I realized that my 9 inch housing wasn't machined deep enough and that my axle bearings were keeping the brake backing plate from mounting directly to the housing. Took some measurements and had a friend machine just enough space in the backing plate so that it mounted directly to the housing and not the axle bearing.
Old 02-12-2009, 07:20 PM
jetlag's Avatar
2000TransAm, that is weird...did you buy the housing new or used? Where did you get it?
Old 02-13-2009, 09:17 PM
Bought it brand new from driveline solutions. Took that route because I didn't feel like sending everything off again. Moser sent me 2 driver side axles and my car was down for a few weeks already. Everything works fine now except for a leaky axle seal.
Quick Reply: Backing plate T-bolts
